File Request Ordinateur portable Yoga 11e 5e génération (Type 20LM) (ThinkPad) BIOS 17833-1M
user51023
KONE BADARA ALY
Bonjours besoin du bios de Ordinateur portable Yoga 11e 5e génération (Type 20LM) (ThinkPad) BIOS 17833-1M
je n arrive pas copier le bin origine
SVP dans l attendre d une suite merci d avance
Hello, I need the BIOS for a Yoga 11e 5th generation (Type 20LM) (ThinkPad) laptop, BIOS 17833-1M.
I can't copy the original bin file
Please, while awaiting further developments, thank you in advance.
  • Yoga 11e 5th update.zip
user51023
KONE BADARA ALY
VOICI LE NUMERO DE MON BIOS ET CELA FAIS 128Ko QUI FAIS 16Ko OR CE QUE VOUS AVEZ DONNE EST UNE BIN DE 8Ko POUR UN BIOS DE 64Ko
HERE IS MY BIOS NUMBER, AND IT IS 128KB, WHICH IS 16KB, BUT WHAT YOU PROVIDED IS AN 8KB BIN FOR A 64KB BIOS.
my friend , the 128KB is for EC ic
you should locate bios ic and program it
Yes, indeed, but the BIN file you sent is 8KB in size.
its 8MB
that KB is just the suffix
you can go to file properties and check the size which is 8MB
here is other file :
  • update.zip
good luck
if you cant read original bios then maybe the issue is related to chip faulty
user51023
KONE BADARA ALY
ouii cest ce que je me suis dis donc je prend autre bios de 8 kb pour le programme a nouveau
mais ce que je n arrive pas a comprendre ma puce a une taille de 128 KB
Yes, that's what I thought, so I'm using another 8kb BIOS for the program again.
But what I can't understand is that my chip is 128 KB in size.
i dont know about this
but i think you located wrong ic
you need to check more on the board
you are welcome
good luck
