File Request IO for Lenovo IdeaCentre 310-20IAP
CyrusCC
CyrusCC
BM6G28 & IAPLSB
AIO 310-20IAP
Hi,
Please provide me the IO dump file for above AIO PC which I found 2 different MB model numbers for it (IAPLSB Rev: 1.0 and BM6G28 Rev: 1.0). The IO IC is "IT8738E" and its programmable IC is "25D05BT". I believe the dump file I have is damaged as the programmer can give me an error regarding pin 7 damages.
Regards
CyrusCC
CyrusCC
Thanks for your reply. Those files are for different models. But there has to be another 64KBit or 128KBit file for EC_Rom1 IC which is closed to the IO chip. The IO and its programmed IC are mentioned above.
Regards
Regards
  • IT8738E.BIN
CyrusCC
CyrusCC
The file you sent is for ITE8731 and not 8737E. Please check it. Also, please check the file I uploaded which I'm not sure if it's ok or not as it is only 64KB.
  • GD25D05 - EC_ROM - FR.BIN
  • IT8738E.BIN
CyrusCC
CyrusCC
I don't understand why you did it this way. you just change 1 to X for only the first part (and not both), reducing the length of the file and think it will solve the case? I am so disappointed.
there is no EC or IO file for the device you request
there are only 8mb and 16mb files
