that one didnt helpBios - asus rog strix x370-f gaming -ver 5216 bios
asus rog strix x370-f gaming -ver 5216 16 mbdr-bios.com
that one didnt help
board does ram and cpu check but doesnt boot
i have 0401 version also gets to vga check status on the led lights but doesnt boot
i did and it doesnt workjust try the file
unzip the file !i did and it doesnt work
bin file is about 16MB and this one is 7.8
i have done that and write it to IC and it didnt workunzip the file !
sorry didnt look after unzipyou said the file is 7.8 MB !
in this case you need to check other parts of the board firstsorry didnt look after unzip
but it didnt help me after i tried it
the pc was working when customer tried to update bios for newer CPU to install on the board ,,then it crashed to them in the middle of the update procedure , after that it wont turn on all the way to boot it stops on CPU or VGA check it depends which version i write in the IC
i will do that ,,already tried another cpu,ram and vga ,,,, could it be that the IC is bad ? it writes the file in and does the verify without errorin this case you need to check other parts of the board first
the bios which sent to you is tested working
mane , Salimeh Bolboli , Support Staff no.1 , Roollice , PaulWoll , user17519 , madhawazu , pvtmatrix
