lkcomputers
- MotherBoard Model
- 5B21B84630
- Laptop Model
- lENOVO Flex 5 14alc05
Good day Need bios for Lenovo Flex 5 14alc05. Unit did bios update but failed
Thanks Tried this update but still no display, Caps and FN lock led static on. any help on this
i think the problem is not related to bios file .I get this error on Neo Programmer but rund normal on ASP programmer
CRC32 = 0x99CF8B66
Current programmer: CH341a
16:30:08
Programming memory(verifying)... Main Memory
Verification error on address: 0x00000000, Device: 0x00, Buffer: 0x02
Execution time: 00:00:00.074
Get this from AS Programmer.i think the problem is not related to bios file .
it seems the problem is from programmer device.
also when device goes off while bios update, usually cause problem for other parts of the board too.
check the bios ic chip first.
Can i get schematic of board to locate ICi think the problem is not related to bios file .
Meaning replace the IC ( BIOS) Chip?Can i get schematic of board to locate IC
send board model i checkCan i get schematic of board to locate IC
check if it has faultyMeaning replace the IC ( BIOS) Chip?
I can read it write to it normaly.check if it has faulty
Any other way to check if faulty as i can program it with no issues. Will it be best to then replace the BIOS ICI can read it write to it normaly.
lkcomputers , Vahab Hemmati , Salimeh Bolboli , itec1978 , user49177 , user46292 , ebubekir soyalp , SSV , user55833 , Edgar Cortez Jara , qkhafeez , JorgeJACG , leulseged , Saleem Khan , UgurKozlar , afonso , jovinkjose
